A & D Medical - UC-355PBT-Ci
by A & D Medical
Premium Wireless Weight Scale with Extra Wide Base
Advanced, motion tolerant, wireless weight scale with extra wide base and high capacity that provides trusted accuracy and reliable measurements every time.
  • Step on technology that automatically starts after user steps on scale
  • Stores 200 measurements in memory
  • Each measurement is date and time stamped
  • Extra wide base
  • Carpet tray option
  • Precision sensors to capture accurate measurements
  • Motion tolerance technology that can generate accurate measurements, even during slight movements
  • 550 lb capacity
  • Minimum Display/ Resolution    0.2 lb between 0-220 lb 0.5 lb between 220-550 lb 0.1 kg between 0-100 kg 0.2 kg between 100-250 kg
  • Unit Dimensions     16.4" (w) x 14.2" (d) x 1.5" (h)
  • Weight (Lbs)    10 lbs, with batteries
  • Memory    200
  • Measurement Range    11-550lb
  • Power Supply    4 AA-size Batteries
  • Number of Measurements (battery)    Approx. 1 year
  • Wireless Communication    Bluetooth
