Autoclave
The steam autoclave B is commonly seen in operating theaters, dental rooms, ophthalmology departments and biomedical research institutes to sterilize autoclavable equipment and supplies, such as surgical instrument, dental appliance, surgical dressing, laboratory glassware, injection device, etc.
- Sterilization temperature: 121°C, 134°C
- Display: Wide LCD display
- Test cycle: Bowie & Dick test and vacuum test
- Pre-vacuum: 1-time and 3-time pre-vacuum treatments are both available for one machine.
- Special microorganisms to be inactivated: HIV, HBV, prion (causes mad cow disease), spore and other viruses
- Sterilization record: The sterilization record can be printed on papers by a mini printer, or be stored in a USB disk.
- Sterilization cycle: Our steam autoclave has different sterilization cycles, such as general sterilization cycle (in accordance with European standard), 134-PRION cycle (with a longer plateau time of 18 minutes to kill prion protein), as well as other cycles for unwrapped solid, rubber and plastic loads.
- Safety consideration: Temperature protection is available at three places including the steam generator as well as the inner and outer sides of sterilization chamber, while the door lock is protected both manually and pneumatically. As a result, misoperation won’t lead to a disastrous consequence
