JOINCHAMP - ZC300-2
by JOINCHAMP
Dental Compressor
The dental compressor is able to generate clean, oil free compressed air in a highly efficient way, and it is meticulously crafted to better fit for integrated dental unit. Our dental instrument has exceptionally low noise levels while running, thus providing a quiet work environment, and this is both healthy and relaxing for dentists and patients. The low noise is resulted from a special structure which could effectively reduce the noise to lower than 65dB (for ZC300-1) when generating compressed air. Our dental compressor is fitted with a water drainage outlet. Hence, water in the compressed air is filtered and then discharged from this drainage outlet. The internal and external sides of the cylinder are coated with an environmentally friendly layer respectively. As a result, the cylinder is easy to clean, and the compressed air is very clean.
  • Power supply    220V±10%, 50±1Hz
  • Power    1100W
  • Production capacity (in 0.4Mpa)    120L/min
  • Max. production capacity    140L/min
  • On/off pressure    0.55/0.75Mpa
  • Operating pressure of safety valve    1.0Mpa
  • Starting pressure    0Mpa
  • Noise level    <68dB
  • Air container volume    71L
  • Ambient temperature    +10~+40°C
  • Ambient humidity    ≤80% RH
  • Ambient pressure    90~106Kpa
  • Continuous working time    ≤4h
