Stille-Sonesta - imagiQ
by Stille-Sonesta
Surgical Table
The imagiQª Surgical Imaging Table is designed for a wide variety of surgical procedures, particularly those requiring a mobile C-arm. The imagiQ has 4-way tabletop float capability and a unique cantilevered design. The result is a large imaging field providing the surgeon excellent visualization. Both lateral tilt and tabletop float can be accomplished concurrently, reducing procedure time and C-arm adjustments. The radiolucent, carbon-fiber top allows superior imaging, and a large unobstructed floor-clearance area provides complete C-arm maneuverability. Standard side rails combined with an "anesthesia friendly" head support make imagiQ the perfect choice.
7RepliesWed Jan 08 2020 | Service and owner manual Can anyone help me in getting a service manual for this bedReply |
1ReplyMon Jul 02 2018 | Stille ImagiQ Table User Manual Can anyone help with getting a users manual for the Stille ImagiQ Table. Tank you.Reply |
4RepliesThu Nov 17 2016 | Stille surgical table service manual Good Afternoon, does anyone have a service or operators manual for the Stille imaging table?
Thanks, |
| Height | 28 in to 43" |
| Weight | 606 lbs |
| Tredelenburg | 25 degrees |
| Patient Weight Capacity | 440 lbs |
[*] Table top length 77"/87" 196/221cm (with/without detachable head section) [*] Table top width 22" 56cm (excluding accessory rail) [*] Imaging area length 72"/60" 183/152cm (with/without detachable head section) [*] Imaging area width 21" 53cm [*] Imaging Length 60 152cm [*] Imaging Length 71 180cm (with headrest) [*] Lateral travel 10" 25cm [*] Longitudinal travel 27" 69cm [*] Lateral roll +/-15 degrees (combined lateral tilt and pan capable) [*] Table top composition ultra thin carbon fiber [*] Table top radiolucency 1.1 mm Al equivalent [*] Table pad composition 3" (7.6cm) thick, slow recovery foam
