JOINCHAMP - ZC-S700
by JOINCHAMP
Integral Dental Chair
ZC-S700 integral dental unit is designed ergonomically and modernly. It's elegant and with great attention to details. It's the first floor type unit of Joinchamp brand. Thick chair base with imported steel frame makes S700 one of the most stable units among our products.
  • The floor-type unit body ensures stability of the whole dental unit.
  • The Italian FARO operating lamp and articulated arm features accurate positioning, concentrated light, light weight and flexible movement.
  • Comfortable for rest on: This dental chair is designed with a unique structure, which is stable and comfortable, ensuring patient comfort.
  • Convenient to use: This control panel of this dental unit is tilted, making it easier for dentists to control. It is an LCD screen, offering a clear display of the operating status.
  • Exquisite craftsmanship: The housing on the dental chair unit is made using injection molding technology, which ensures the housing is uniformly jointed and easy to clean.
  • The dental chair package is designed with unique structure, which follows the curvature of the human back to ensure the backrest remains close to the patient, and offer additional patient comfort.
  • This dental unit has nine recorded seat positions set through easy programming to be suitable for different treatment positions and save treatment time.
  • There are waterpipes disinfection and flushing system, which helps to prevent cross-infection.
  • The main parts are imported. Unit box and cuspidor bowl are rotatable. And it has new designed assistant table with comfortable leather upholstery.
  • Power supply: 220V, 50/60Hz
  • Air source pressure: > 0.55 MPa
  • Water source pressure: 0.2-0.4 MPa
  • Imported handpiece tubing: 3 pieces
  • Pressure gauge
  • 3-way syringe: 2 pieces (cold & warm)
  • External 24V X-film viewer: 1 set
  • Control system with LCD display: 1 set
  • Deluxe saliva ejector (water) and powerful suction (air)
  • Seamless rotatable ceramic cuspidor bowl
  • Faro MAIA operation light originally from Italy
  • Anti-retraction system
  • 9 keys deluxe larger assistant control panel
  • Cup filler/ tray/ tissue box
  • Purified water bottle/ Disinfectant bottle: 1 piece each
  • Floor mounted unit box: 1 set (match with different colors)
  • All inner air and water tubings are from USA
  • Built-in injecting water purified system
  • Stronger chair metallic frame and thicker metallic chair base
