Dental Chair
S400 2020 type dental chair package is designed with simple and elegant style. Its streamlined shape highlights the three-dimensional beauty. Classic and modern color matching meets your individual needs.
- Equipped with 9 memory positions, the dental unit can be set by three dentists A, B and C. Every dentist can set three commonly-used chair positions
- Spitting position: During the treatment, when the patient needs to spit saliva or dirt, just press the "spitting" button, the dental chair will switch from the treatment position to the spit position, which is very convenient. The light will automatically turn off (if it is on) and the flushing water will turn on automatically; after spitting, press the "spitting" button again, the dental chair will return to the treatment position. At this time, the light will turn on and the flushing water will stop automatically.
- Chair interlock system: During treatment, when the dentist uses a handpiece or a scaler, all movements of the dental chair are locked to prevent accidental injury due to the malfunction of the dental chair.
- Pads on the tray can be removed and disinfected, convenient and hygienic.
- Top-mounted doctor table with hided air lock valve can be adjusted to the height as you need.
- Precise design of the rod can be easily pulled out and put back without any traction force, more flexible to operate at large angles, avoiding the dropping of handpieces and giving the best operational experience to dentist.
- Handpiece pad can be removed and disinfected, easy for cleaning.
- It¼s convenient to remove the stainless steel tray for disinfection and cleaning
- Power supply: 220V, 50/60Hz
- Water source pressure: 0.2-0.4 MPa
- Air source pressure: > 0.55 MPa
