Biocare - iE 300
by Biocare
Digital 3-Channel ECG
  • High resolution 5 inch color LCD screen.
  • Simultaneous 12 leads acquisition .
  • Digital ECG technology with 24 bit resolution 8000 samples / sec.
  • Frequency response 0.05 Hz ~ 250 Hz.
  • Automatic ECG diagnosis for adults, children and newborns.
  • Simultaneous recording
  • Functions: AUTO, Manual and Rhythm.
  • Thermal printer with 80 mm paper.
  • Ability to print in the following formats: 1 X 12, 1 X 12 + 1R, 3 X 4, 3 X 4 + 1R, 3/2.
  • Printing speeds (5, 6.25,10,12.5,25,50) mm / s.
  • Visual and audible alarms for: low battery charge, blank paper tray or disconnected cables.
  • Built-in lithium battery.
  • Battery charge level indicator.
  • Easy operation with one-touch shortcut keys
  • Up to 300 seconds of parsing - facilitates arrhythmia detection.
  • Pest repellent filters: EMG, Baseline wander and AC.
  • Automatic and manual sensitivity adjustment in 7 levels (1.25, 2.5, 5, 10, 20, 10/5, 20/10) mm / mV & Auto Gain.
  • Implantable pacemaker detection.
  • Freeze screen.
  • Internal digital data storage memory with a capacity of 3000 files.
  • Two USB ports for expanding the internal memory and connecting the barcode scanner.
  • Network port (LAN) for sending data to a central station.
  • Weight of device with battery = 1.3 kg.
  • CE mark & ISO.
  • 10-pole patient cable.
  • 4 clip on electrodes.
  • 6 suction cup electrocardiograms.
  • Power cord
  • AC / 220V power supply.
  • Rechargable battery.
