Ohio Medical - Mini OX 3000
Oxygen Monitor
Ohio Medical carries the MiniOX3000 for continuous oxygen monitoring, the MiniOX100 Oxygen Analyzer for spot-checking O2 percentage, the MiniOX 200 Oxygen Analyzer for checking the oxygen percentage accuracy in blenders and concentrators and the MiniOx 200E which is especially useful for in-line monitoring of oxygen concentrations.
- High & low oxygen concentration alarms
- Automatic calibration
- Battery life indicators with alarms
- Sensor/cable disconnect alarm
- Alarm verifi cation indicator
- Extra-large display window
- Integral tabletop stand
- Range: 0-100% O2
- Resolution: 00.1 O2 increments
- Battery Indictor - Stage 1: Warning that approximately six hours of monitoring life remain. “LO BAT” (Global version displays " “ ) appears on display beep sounds every 30 seconds until battery is replaced or Stage 2 occurs.
- Battery Indictor - Stage 2: Alarm that proper operation is not assured.
- Monitor shuts down; audible and visual alarms are activated.
- Power supply: One 9-volt battery
- Battery lifetime: approximately 1500 hours
- Cable length: 10 feet
- Product Dimensions: 5.98 x 3.26 x 1.31 in. (15.18 x 8.28 x 3.32 cm.)
- Product Weight: 9.2 oz.
- Operating temperature range: 32 to 104 F (0 to 40 C)
- Storage temperature range: -40 to 158 F (-40 to 70 C)
- Humidity: 5-95% RH (non-condensing)
- Alarms: Pulsating alarm/ fl ashing LED
- Shipping Dimensions: 10.25 x 7.56 x 6 in. (26.03 x 19.20 x 15.24 cm.)
- Shipping Weight: 1.7 lbs. (0.77 kg.)
