Inceler Medikal - Spark ESWL
Electrohydraulic Lithotripsy System
The most important factor in the success of ESWL treatment is focusing. The Compact and easily controllable structure of the system is important factor for focusing procedure. In Spark ESWL system , All procedures can be performed by a hand-held remote control. During lithotripsy, focus can be controlled from any desired location.
0Replies3 years ago | Inceler Medikal SPark ESWL Inceler Medikal Spark ESWL Reply |
VIDEOS
- Energy Source(Working Principle) Electrohydraulics
- Patient Touch Membrane (Dry Touch)
- Localization Fluoroscopy and/or Ultrasound
- Focal Penetration 130 mm
- Unit control Hand Control Unit
- Focusing Method Ellipsoid reflector
- Electrode Type Long Life ( a couple 40 sessions = 80.000 shocks)
- Operating Voltage Variable 0 – 21 KV
- Device Sturcture Compact
- Main Unit Dimensions 90 cm x 190 cm X 191 cm
- Water System Closed loop circuit with water cushion
- Pressure regulation and 12 lt. Water capacity
- Main Body Weight 285 kg
