Doctor & Assistant Dental Stool
The A-dec 500 doctor's and assistant's stools offer a dynamic seating system that conforms and moves with the body. With years of research behind it, the innovative A-dec 500 stool is strategically engineered to help you feel your best, so you can perform your best.
- Tilt Seat. Distributes weight from seat to feet allowing proper circulation.
- Contoured Backrest. Cradles the spine, while encouraging blood flow. Contoured backrest is standard on the A-dec 500 doctor’s stool and optional on the A-dec 500 assistant’s stool.
- Whisper Quiet Casters. New design provides smooth, ultra-quiet movement on both carpet and hard flooring.
- Adjustment Controls. Labeled paddles are easy to access for quick adjustments and easy cleaning.
- Backrest Height Control. A push button makes access and one-handed adjustment easy.
- Upholstery. Minimal seams make clean up easy.
- Two Cylinder Heights (A-dec 500 doctor’s stool). Measure from hips to the feet. Above 34" - choose tall cylinder. Under 34" - choose short cylinder.
- Height-Adjustable Foot Ring (A-dec 500 assistant’s stool). Helps practitioner maintain correct posture.
