Wells Johnson - ELITE
by Wells Johnson
Infiltrator/Aspirator
The Elite combines high powered infiltration and aspiration into a single vertical unit with a small footprint.
  • High Infusion Rate 0-1200 ml/min
  • Precise Settings and Controls
  • High Flow Rate 6.8 cubic ft/min
  • Eye Level Controls
  • Small Footprint 18”x18”
  • Infiltrator Specifications
  • Flow Rate: 0-1200 ml/min
  • Pressure: 25 PSI continuous
  • 40 PSI intermittent
  • Aspirator Specifications
  • Maximum Vacuum: 29+ in Hg
  • Maximum Flow Rate: 6.8 cubic ft/min
  • Number of Pumps: 3
  • Horsepower: 1HP
  • Weight 218 lbs
  • Select Voltage 110-120VAC 50/60Hz , 220-240VAC 50/60Hz
