Autoclave
A correct autoclave is an essential component for an office-based cosmetic surgery practice. The large chamber size of the RM9 can accommodate cannula lengths of up to 35 cm (assuming the use of 2 pc cannulas). The RM9 Series Autoclave has an intuitive display and simple prompts that help you easily select the cycle you need…whether it is for unwrapped items, pouches, packs or hand pieces.
- If the door is not closed completely or the reservoir water level is low, the LCD display will provide the appropriate message.
- In either case, sterilization can’t continue until you’ve attended to the unit.The RM9 Series Autoclave offers easy, effective sterilization and is the perfect choice for the single practitioner
- Chamber: 9” diameter, 15” depth, 3.5 gal usable volume
- Two large trays: 12”L x 7.31”W x .88D
- Two small trays: 12”L x 5.62”W c .88”D
- Overall Dimensions: 18.81”L x 15”W x 16.44”D
- Water Reservoir Capacity: .88 gal
- 110V
