Wells Johnson - IV Bag Warmer
by Wells Johnson
IV Bag Warmer
Wells Johnson IV Bag Warmers are accurate, easy to use, safe and durable. The design incorporates attractive appearance, a dip free cover holster, and pocket handles so users can easily move the water bath's location. A microprocessor achieves precise temperature control regardless of how the unit is loaded.
Calibration is performed directly from the front panel. This durable and dependable unit features a unique lid design that allows condensation to drain back into the tank without spilling. Our engineers have also incorporated a gasket around the water bath tank to prevent water from dripping onto controls. A warm-air-jacketed design radiates heat up the sides of the tank, not just from the bottom. This eliminates any hot spots. A non-contact, recessed heating element is used to prevent burnouts due to lack of water.
Tank construction is one-piece, using drawn-type stainless steel, eliminating any seems to leak. Resulting radius corners make cleaning easy. Housings have a high quality textured powder coat finish. This electrostatically applied surface not only eliminates rust and chipping but is strongly resistant to nicks, scratches and corrosives.
  • Easy-to-Clean Stainless Steel Tank
  • No Drip Lid Design
  • Pocket Handles for Easy Lifting
  • Air-Jacket Heating Eliminates Hot Spots
  • Recessed Heating Element Prevents Burnout
  • Weight 27.00 lbs
  • Interior Dimensions WxDxH in. 12'' x 13'' x 6''
  • Exterior Dimensions WxDxH in. 14.75'' x 19'' x 8.5'' cover adds 3.5 inches to height
  • Tank Capacity 14 Liters
  • Temperature Range 5° above ambient to 80° C
  • Temperature Uniformity +/- 0.25° at 37° C
  • Electrical Specifications Volts: 120V Hertz: 50/60
  • Watts: 500W
  • Amps: 5.0A
  • Temperature Control Microprocessor
