Dual Infiltration System
The premiere high-powered, efficient peristaltic pump for virtually effortless infiltration.
- 2 Infiltration Cannulas
- 2 Infiltration Handles
- Infiltration Tubing (case of 5)
- Pneumatic Foot Switch
- Custom IV Stand
- Spinal Needle
- Maximum Flow Rate 1300ml/min (with specified tubing)
- Continuous 25psi
- Intermittent 40psi
- Weight 11 lbs
- Dimensions 7.25” x 12.5” x 6.25”
- Power 100-240 VAC, 50/60Hz
- Drive single direction
- Motor 0 to 1050 rpm +/- (load dependent)
- Maximum Vacuum 24”hg
