Thermo Scientific - Jouan IG 650
by Thermo Scientific
CO2 Incubator with Humidity Control
Jouan IG650 CO2 Incubator with Humidity Control Product detail: Ideal for cultures on semi-solid media or very low volumes (type microplates): Total control of evaporation of the culture media. Stable, homogeneous temperature: Recovery under five minutes after 30 sec opening with patented heat generator. 40 liter water jacket plus insulation
-mmeery
Wed Sep 29 2021
service manual
Hi, I'm looking for the service manual of Jouan IG 650 thanksReply
2
-mmeery
Thu Sep 23 2021
Service Manual
Hi, did someone have the service manual of the incubator IG 650 of the Lab? My equipement has a CO2 at 6.5 CO2, I have try to put at 5 % but it doest stay. so think that I have to calibrate , so i need the manual if someone has. thanksReply
  • Ideal for cultures on semi-solid media or very low volumes (type microplates): Total control of evaporation of the culture media.
  • Stable, homogeneous temperature: Recovery under five minutes after 30 sec opening with patented heat generator. 40 liter water jacket plus insulation.
  • Constant Relative Humidity: Fast RH recovery thanks to built-in patented vapor generator
  • Adjustable Relative Humidity: Range 65% to 98% to provide a natural environment. Not just a display.
  • Protected gas supply: Twin CO2 inputs with built-in shuttle valve maintains the supply when one cylinder empties.
  • Precise culture conditions: %RH accuracy +1%. Temp. accuracy +0.1°C, homogeneity +0.25°C. CO2 accuracy +0.1%, homogeneity +0.25%.
  • Protection against contamination: HEPA-type 0.22µm sterile membrane filtration of gas and water.
  • High precision: Infra-Red CO2 detector, independent of temperature and humidity. Microprocessor controlled.
  • Thermal buffer: Water jacket and insulated walls protect against temperature variation.
  • Fully alarmed: All control parameters plus water level and door ajar.
  • Traceability guaranteed : Optional RS 232C interface enables monitoring and remote control of the incubator.
  • Space saving independence: Units are stackable while retaining individual controls.
  • Temperature range: Room temperature + 5 ° C to 50 ° C
  • CO2 detector: infrared
  • Size: 90 x 73 x 60cm
  • Inner dimensions: 66 x 48 x 45 cm
  • Outer material: steel
  • Interior Material: stainless steel
  • Inner door: safety glass
  • CO2 Incubator Jouan IG 150
  • Water jacket volume 85 litres maximum capacity 154 litres
  • Maximum number of sheets (3 pcs. are supplied
  • Empty weight approx. 80 kg
  • Weight filled with water approx. 170 kg
  • Weight with packaging approx. 100 kg
  • Required power supply: 230 V, 50 or 60 Hz.
  • Power consumption max. 800 VA, normal consumption at 37 °C: 220 Watt
  • Colour of the connections brown = phase, blue = neutral, yellow/green = earth
  • Ambient temperature 15 - 30°C
  • CO2 inlet pressure 300 mbar - 3 bar
  • Temperature range in the interior from 5°C above room temperature to 45°C
  • Working range with CO2 gas 0.0 % to 20.0 0/0
  • Article weight: 80,00 kg
  • Type IG 150
