NeuroLogica - CereTom NL3000
by NeuroLogica
Portable CT Machine
The CereTom is an 8-slice CT scanner that delivers the highest quality non-contrast, angiography and contrast perfusion scans in any patient location. Its combination of rapid scan time, flexible settings and immediate image viewing, makes it an indispensable tool to any clinician needing real time data on critically ill patients.
-dario1
Thu Jan 13 2022
Error
Wsa Error 10057 on port 56575 I need help Reply
6
-dario1
Tue Oct 12 2021
manual
Service Manual CERETOM NL3000 from NeuroLogica , instal workstationReply
  • Noise kernel Smooth
  • Noise, % at â¤25 mGy 0.3% at 25 mGy (2.5 rads)
  • Mtf kernel Bone 16
  • FWHM of SSP at 1 mm 1.22
  • Low-contrast resolution, mm at % at â¤20 mGy 3 mm at 0.3% at 2 rads
  • 10% MTF, lp/cm 14.3
  • 50% mtf, lp/cm 10.5
  • High-contrast spatial resolution Yes
  • Gantry angle deg 0
  • Gantry weight, kg 400
  • Scan localizer Laser
  • Gantry dimensions, h x w x d, cm 153 x 133 x 72
  • Gantry opening, cm 32
