Ellex - LDP3106-U
by Ellex
Surgical Laser
The Ellex Ultra Q is the ophthalmic industry’s premier capsulotomy and iridotomy laser. With a firing rate of up to 3 hertz, it is the industry’s fastest photodisruptor. The Ultra Q also features a custom-designed laser cavity tested to deliver an exceptional lifespan, as well as a fine, two-point focusing system that provides a level of precision other photodisruptors simply cannot achieve.
-germangp
Mon May 05 2025
Ellex-Handbuch - LDP3106-U
Saludos donde puedo ubicar o si me pueden facilitar el manual de Yag Ellex LDP3106
Translation:
Greetings, where can I find or if you can provide me with the Yag Ellex LDP3106 manual?
  • Laser Source Q-switched Nd: YAG
  • Wavelength 1064 nm
  • Energy 0.3 to 10 mJ, single pulse-continuously variable
  • Pulse Width 4 ns
  • Burst Mode 1, 2 and 3 pulses per burst, selectable
  • Spot Size 8 µm
  • Posterior Offset 100 to 350 µm, continuously variable
  • Cone Angle 16 degrees
  • Repetition Rate up to 3 Hertz
  • Aiming Beam red 635 nm, adjustable intensity
  • Magnification 10x, 16x, 28x
  • Cooling air cooled
  • Electrical Requirements 100-240 VAC, 50/60 Hz, 500 VA
  • Depth 28 inches
  • Height 28 inches
  • Width 28 inches
