Diplomat Dental S.R.O. - DC310
Dental Chair
The DC310 (upper instruments hose delivery system) is available in a chair-mounted version. The pantographic arm has a mechanical or electro- pneumatic brake system enabling the dentist to set the dentist block into the optimal working position. The swiveling spittoon bowl can be electronically controlled from both the dentist’s and assistant’s elements. The pantographic arm-mounted assistant’s element is height-adjustable. The assistant can control selected functions using a membrane keyboard.
0Replies2 years ago | SERVICE MANUAL I AM LOOKING FOR A SERVICE MANUAL FOR A DIPLOMAT CONSUL DC310 DENTAL EQUIPMENT THANKS FOR YOUR SUPPORTReply |
- 7-inch color resistive or capacity
- The panel features a capacious swiveling stainless steel or plastic tray table with two trays.
- POWER SUPPLY 230 V ± 10%
- MAXIMUM POWER INPUT AT 230 V/50 HZ 400 VA + 10%
- INPUT AIR PRESSURE FROM 0.45 TO 0.8 MPA
- INPUT WATER PRESSURE FROM 0.3 TO 0.6 MPA
- DENTAL UNIT WEIGHT (NETTO) – CARRIED 90 KG + MAX. 20 KG ACC. TO VERSION
- TYPE OF SHOCK PROTECTION CLASS I EQUIPMENT
- DEGREE OF SHOCK PROTECTION APPLIED PARTS OF B TYPE
- WATER TEMPERATURE FOR THE CUP 36 ± 5 °C (WITH HEATER FITTED)
- TRAY TABLE RECOMMENDED MAX. LOAD 1.5 KG
- SIDE TABLE RECOMMENDED MAX. LOAD 3 KG
- PACKAGING DIMENSIONS (LENGTH/WIDTH/HEIGHT) 1580 X 1070 X 680 MM
- DENTAL UNIT WEIGHT WITH PACKAGING – CARRIED 145 KG + MAX. 35 KG
