Centrifuge
The DM0412 Clinical Centrifuge is ideal for the separation of serum, plasma, urea, blood samples and other routine applications in hospital and research laboratories. The DM0412 conforms to international safety standards and regulations.
-MedWrench Crystalyn
Tue Jan 25 2022
Scilogex DM0412
Scilogex DM0412Reply
3
-jkh07
Mon Jan 24 2022
E ~ 10
Good day, I just want to ask does anyone know what is the meaning of E~10 Error code in Dlab DM0412 or even in Dlab/Scilogex Centrifuge in general? Thanks for the reply.Reply
VIDEOS
Scilogex DM0412
  • High accuracy of speed, excellent performance
  • CPU controls all operating parameters including speed and time
  • RPM or G-force can be set and displayed
  • Operation can be timed from 30 seconds to 99 minutes or continuous running
  • Timer commences once the set speed is reached, so the separation time is more accurate
  • Gentle braking at low speeds with efficient separation
  • Parameters can be modified after the set speed is reached
  • Quick spins are possible by pressing and holding PULSE key
  • Automatic release the lid when operation has stopped to save processing time
  • Easy-to-read backlit LCD processing display and sound alert
  • Can be pulse accelerated and held at speed
  • High strength plastic rotor and excellent balance technology for quiet and stable operation
  • Brushless motor drive quickly and effortlessly accelerates the rotor to set speed
  • Weight 19lbs
  • Dimensions 22x19x18 inches
  • Centrifuge: DM0412
  • Speed: 300-4500rpm, 100rpm increments
  • Rotor Capacity: 8 x 15ml centrifuge tubes, 12 x 10ml/7ml/5ml vacutainer
  • Max. RCF: 2490g
  • Run Time: 30secs to 99mins Timer or Continuous Operation
  • Voltage: 110-240V, 50/60Hz
