Brumaba - Varius
Operating Table
The right choice in every situation. The universal and mobile operating table is, as the name suggests, our most variable BRUMABA operating table. Flexible application in outpatient surgery, both for orthopedics and in plastic/aesthetic and reconstructive surgery. X-rays are also no problem for him. The foot section is divided into two parts, separately adjustable and spreadable. With the Airplane function, you tilt the surgical field towards you, thus protecting your back. The VARIUS operating table opens up new possibilities for interdisciplinary use! Due to its versatile use, it is also an ideal solution in outpatient surgery, for example. It guarantees an efficient as well as economical OR organization, whether in clinic or practice. Its long service life and low-maintenance technology make it a reliable tool for daily use.
1Reply2 years ago | Falut codes and service manual Hello, Can someone help me with the fault condes of a Brumaba OP model Varius. I have Fault 0001 and 0025. Can anyone help me with the service manual for this equipment? Thank youReply |
- Airplane function (longitudinal axis tilting)
- Two-part leg section, can be folded down and spread separately
- Solid stainless steel construction
- Standard rails integrated in frame rotated 90°
- X-ray capability
- 1-2 weeks of battery operation per charge
- Manual remote control
- Foot switch (optional)
- Memory function with 8 programs
- Telescopic head section with head rest
- 3-dimensionally adjustable head rest
- Back section extension for length adjustment
- 300 kg maximum patient weight
- 35 upholstery colors
- Length min (mm) 1770
- Length max (mm) 1940
- Total width (mm) 555
- Own weight (kg) 207
- Max. Load (kg) 300
- min height without cushion (mm) 555
- max height without cushion (mm) 985
- Cushion height (mm) 65
- Axial tilt left (°) 17
- Axial tilt right (°) 17
