Brumaba - Genius Eye
by Brumaba
Operating Table
BRUMABA has developed the GENIUS EYE as a mobile operating table especially for ophthalmology. You can adjust the headrest in three dimensions, so you always have a perfect view of your patient’s eye and the head and neck are supported comfortably and stably. Even in the covered state, you can readjust the patient position thanks to the automatic length adjustment of the head shell. Excellent legroom and optimal access for the surgeon provide perfect working ergonomics and space for your microscope and phacoemulsification foot controls. Sit with your back upright and the BRUMABA operating table will do the rest.
  • Integrated armrests, fold-down push handles head side, push handles foot side
  • Ergonomic lines of the upholstery
  • 1-2 weeks battery operation per charge (150 cycles)
  • Telescopic headrest with dome 3-dimensionally adjustable headrest
  • Hand-held remote control
  • Foot switch (optional)
  • Memory function with 8 programs
  • Backrest extension for length adjustment
  • 250 kg maximum patient weight
  • 35 upholstery colors
  • Length min (mm) 1795
  • Length max (mm) 1983
  • Total width (mm) 767
  • Own weight DTA (kg) 160
  • Own weight DTN (kg) 140
  • Max. Load (kg) 250
  • min height without cushion (mm) 515
  • max height without cushion (mm) 945
  • Cushion height (mm) 55
