Operating Table
The GENIUS EYE PRO is the professional solution even for longer operations in ophthalmology. The extra thick padding, individually adjustable armrests (option) and the three-dimensionally adjustable headrest provide the best support for your patients. The patented head section allows you to adjust the head shell intraoperatively, even if the patient is already covered. Our smooth-running castors enable back-friendly travel with maximum stability, even with a maximum patient load of 250 kg. The backs of the nursing staff remain healthy and your surgical procedures can be designed to be as economical as possible.
- Extra comfortable upholstery
- Foldable push handles to head side, wider push handles to foot side
- 1-2 weeks battery operation (per charge 150 cycles)
- Adjustable armrests (accessories)
- Extra thick viscous upholstery 3-dimensionally adjustable headrest
- Hand-held remote control
- Foot switch (optional)
- Memory function with 8 programs
- Back section extension for length adjustment
- 250 kg maximum patient weight
- 35 upholstery colors
- Length min (mm) 1795
- Length max (mm) 1983
- Total width (mm) 590
- Own weight DTA (kg) 160
- Own weight STA (kg) 140
- Max. Load (kg) 250
- min height without cushion DT (mm) 465
- min height without cushion ST (mm) 525
- max height without cushion DT (mm) 895
- max height without cushion ST (mm) 815
- Cushion height (mm) 70
