Hettich - MIKRO 220
by Hettich
Centrifuge
The Hettich MIKRO 220 is a centrifuge features a high capacity 48-place angle rotor and 60-place drum rotor for maximum productivity. Higher RCF values reduce production time and offers cost saving capability. Additional rotors include a 24-place swing-out rotor for microliter tubes, 6-place PCR strip rotor and rotors for conical tubes, blood tubes, pediatric tubes, urine tubes and hematocrit capillaries.
-Zeeshubhatti
2 years ago
Error 82
Machine is not working due to errorReply
  • Micro Variety. The MIKRO 220 offers 4 different Microliter Tube Packages ranging from 24 to 48 tubes per run with optional bio-containment. The Microliter Tube Strip Package is also available, capable of spinning up to 6 PCR strips.
  • Process Lipemic samples and save thousands on equipment. Don’t struggle with the high-cost of processing lipemic samples. Process your samples quickly, in-house, and do away with send-outs with Hettich high-speed micro centrifuges.
  • Model    MIKRO 220
  • Electrical requirements 120V 60Hz
  • Max. capacity 48 x 1.5/2.0 mL, 6 x 50 mL
  • Max. blood tubes     12 (up to 10mL
  • Max. conical tubes     6/3 (15/50 mL)
  • Max. RPM/RCF 18,000/31,514
  • Temperature control
  • Ambient
  • Rotor type Swing-out, fixed-angle
  • Dimensions 13 x 16.5 x 12" (WxDxH)
  • Weight 46 Lbs
