Scilogex - SCI506
by Scilogex
Centrifuge
The SCILOGEX SCI506 low-speed centrifuge is supplied with a fixed angle rotor which can hold up to 6 x 15mL/10mL/7mL/5mL tubes adapters included). It is widely used for blood or urine separation in medical routine practice in hospitals, clinics or research institutes.
-MedWrench Crystalyn
Thu Feb 10 2022
Sciolgex SCI506
Scilogex SCI506Reply
VIDEOS
Sciolgex SCI506
  • Speed range 300-5000rpm
  • Rotor speed can be set and displayed in RPM or G-force
  • Two memory programs
  • Two deceleration speeds can be set to suit different applications
  • Easy-to-read display
  • Automatic lid-lock release
  • Maintenance-free brushless DC motor
  • Speed Range    300-5000rpm, increment:10rpm
  • Max. RCF    2350xg, increment: 10g
  • Speed accuracy    ±20rpm
  • Rotor Details    6x15mL/10mL/7mL/1.5-5ml. Inner radius: 93mm. Outside radius: 96mm
  • Run Time    30sec-99min, HD(continuous running)
  • Voltage    110-220V, 50/60Hz
  • Programs Memory 2
  • Acceleration/Deceleration 1 2
  • Weight 11lbs.
  • Advanced features  - Speed/RCF switch; Sound-alert function
