Centrifuge
The SCILOGEX SCI636 Multi-Purpose low-speed centrifuge is ideal for the centrifugation of samples in clinical chemistry, cytology, research laboratories, industrial laboratories, etc. This centrifuge is suitable for tubes with caps, blood collection or urine tubes. Swing-out bucket rotors and adapters can be compatible with standard tubes up to100mL.
- FREE rotor of your choice with purchase
- Suitable for tubes with caps, blood collection or urine tubes
- Speed can be set from 300 - 6000rpm
- Automatic rotor detection
- CPU controls all operating parameters including speed and time
- RPM or G-force are simply set and displayed
- Operation can be timed from 30 seconds to 99 minutes for short run/ continuous run
- Timer commences once the set speed is reached, so the separation time is more accurate
- 9 Acceleration / 10 Brake speed settings to ensure optimal separation
- Parameters can be modified after the set speed is reached
- Quick spins are possible by pressing and holding PULSE key
- Interlock automatic door lock
- 9 procedures stored in memory makes the operation much simplified
- Easy-to-read backlit LCD processing display and sound alert
- A wide range of accessories available (fixed angle and swing-out bucket rotors)
- cTUVus approved for UL and CSA
- Maintenance-free brushless DC motors drive quickly and effortlessly accelerates the rotor to set speed
- Speed range 300-6000rpm, increment:10rpm
- Max. RCF 4300xg
- Speed accuracy ±20rpm
- Capacity 1.5mL to 100mL
- Run Time 30sec-99mins/continuous
- Voltage/Motor 110V, 60Hz / Brushless DC
- Display LCD
- Program Memory 9
- Safety Devices Door Imbalance protectionOver speed & Over temperature detection
- Acceleration/Deceleration time 9↑ 10↓
- Power Single-phase AC220V-240V, 50Hz/60Hz, 6.3A; AC110V-120V,50Hz/60Hz,10A
- Dimension[WxDxH] 445x579x269mm
- Weight 36kg
- Certification CE cTÜVus FCC IVD
- Advanced features speed/rcf switch; Rotor identification
