Mini Centrifuge
Scilogex Ezee Mini centrifuges are ideal for microfiltration and quick spin downs from the walls and caps of microcentrifuge tubes and PCR tubes. The compact design takes up less than six inches of bench space. Easy open clear colored lids are available in two colors. Simply close the lid for acceleration and open the lid for deceleration, or alternatively use the on/off switch to control.
- Max.Speed 7000 rpm
- Max.RCF 2680xg
- Rotor Capacity 8 x 1.5/2.0ml micro-tubes. (8 x 0.5/8 x 0.2ml tubes using included adapters), 0.2mL×16 PCR tubes or 0.2mL×2 PCR 8 strips
- Run Time 30 secs to 99 mins Timer or Continuous Operation
- Dimension [D×W×H] 160x170x122mm
- Weight 0.5kg
- Power AC 100-240V/50Hz/60Hz 20W
- Driving Motor DC motor
- Certification CE cTÜVus FCC MCA
- Available in two colors i.e., green, blue
- Easy-to-use with dual start/stop function
- Maximum speed 7000rpm/2680xg
- Supplied with an 8 place 1.5/2.0ml microtube rotor and 16 x PCR tube rotor & 0.2/0.5ml tube adapters
- Compact design
- Whisper quiet operation, noise level ≤ 45dB
- Ideal for quick spin downs of microtubes and PCR tubes
- Simply close the lid for acceleration and open the lid for deceleration, or use the on/off switch
- Accelerates and brakes in seconds
- Universal voltage
- Rotor change without tools
- cTUVus approved for UL and CSA
