Scilogex - SCI24H
Hematocrit Centrifuge
The SCI24H Hematocrit Centrifuge with AC24P rotor is used for determination of volume fractions of erythrocytes in blood for diagnostic purposes and doping tests and also for separation of micro blood and solutions. It is used for the photometric determination of bilirubin content in neonate blood samples. Hematocrit centrifuge with A24-2P tube rotor, can be used for extraction of DNA and RNA. The SCI24H conforms to international safety standards and regulations.
- Precise control of speed and time separately, excellent performance
- Dual lid lock prevents opening during useCPU controls all operating parameters including speed and time
- RPM or G-force can be set and displayed
- Operation can be timed from 30 seconds to 99 minutes or continuous running
- Timer commences once the set speed is reached, so the separation time is more accurate
- Gentle braking at low speeds with efficient separation
- Parameters can be modified after the set speed is reached
- Quick spins are possible by pressing and holding PULSE key
- Automatic release the lid when operation has stopped to save processing time
- Easy-to-read backlit LCD processing display and sound alert
- Can be pulse accelerated and held at speed
- High strength aluminum hematocrit rotor included (optional fixed angle rotor for 1.5/2.0ml tubes)
- Comes with Hematocrit rotor for 24 x 1mm x 75mm capillary tubes
- Brushless motor drive quickly and effortlessly accelerates the rotor to set speed
- Optional micro-tube rotor: 1.5/2mL×24 max. speed: 14000rpm
- Speed range 200-14000rpm, increment:10rpm
- Max. RCF 18620×g
- Speed accuracy ±20rpm
- Rotor Capacity 2 type
- Run Time 30sec-99mins/continuous
- Motor Brushless DC motor
- Display LCD
- Program Memory 9
- Safety Devices Door interlock,Overspeed detector; Over-temperature detector, Automatic internal diagnosis, Automatic rotor identification
- Acceleration/Deceleration time 30s ↑ 30s ↓
- Power Single-phase, 220V-240V,50Hz/60Hz, 5A; 110V-120V,50Hz/60Hz, 5A 160W
- Dimension[WxDxH] 280×364×266mm
- Weight 10kg
- Certification CE cTÜVus FCC IVD
- Advanced features Speed/RCF switch;Short-time run function; sound-alert function
