Scilogex - SCI-12
by Scilogex
Personal Micro-Centrifuge
The SCILOGEX SCI-12 Personal Micro-Centrifuge is a compact and powerful high-speed centrifuge used in physical and chemistry analysis, biochemistry, cellular and molecular biology, clinical Labs and blood donation centers, and is ideal for high-end research applications.
-MedWrench Crystalyn
Thu Feb 10 2022
Sciolgex SCI-12
Sciolgex SCi-12Reply
VIDEOS
Sciolgex SCI-12
  • Large LCD display provides all visual information
  • Powerful centrifugal force of 15100xg and max. speed of 15000rpm ideal for various applications
  • Supplied with a 12 position 1.5/2.0ml micro-tube rotor
  • Compact design
  • Whisper quiet operation, Low noise ≤56dB
  • Brushless DC motor drive quickly accelerates the rotor to set speed
  • Pulse operation for quick spins
  • Interlock automatic door lock
  • Over-speed detection
  • SCI-12 Plus passed CE, cTUVus, FCC certificates, and MCA test approved for UL and CSA. MCA test according to IEC/EN61010-2-20
  • SCI12 is certified IEC/EN 61010-1
  • Speed    500-15000rpm, increment: 100rpm
  • Max. RCF    15100×g, increment: 100×g
  • Speed accuracy    ±20rpm
  • Rotor Capacity    0.2mL/0.5mL/1.5mL/2mL×12
  • Run Time    30sec-99mins/continuous
  • Driving Motor    Brushless DC motor
  • Display    LCD
  • Safety Devices    Door interlock, Over-speed detection, Over-temperature detection, Automatic internal diagnosis
  • Power    Single-phase, AC110V-240V, 50Hz/60Hz, 3A 100W
  • Noise level    ≤54dB
  • Acceleration/Braking time    11s↑ 09s↓
  • Dimension[WxDxH]    255×245×140mm
  • Weight    6kg
  • Certification    EMC, CE, FCC, ICES, cTUVus, CB
  • Advanced features    Speed/RCF switch;Short-time run function; sound-alert function
