Scilogex - SCI124R
by Scilogex
Refrigerated Micro-Centrifuge
The SCI24R Refrigerated Micro-Centrifuge is a compact and powerful high-speed centrifuge used in physical and chemistry analysis, biochemistry, cellular and molecular biology, clinical Labs and blood donation centers, and is ideal for high-end research applications.
  • Large LCD display provides all visual information
  • Bio-safe aluminum rotor/anti-sample overflow prevents accidental leakage during centrifugal process allowing risk-free microbial contamination
  • Comes with a 24 place rotor, 1.5/2.0mL tubes. Optional adapters for 0.2mL and 0.5mL tubes
  • Pre-cooling to desired temperature ensures optimal protection of the sample before warming
  • Guaranteed 2°C cooling within only 7 minutes of both chamber and samples even at maximum speed and capacity utilization
  • Sound-alert allows your undivided attention on other tasks warming
  • Quiet running, noise level ≤ 54dB
  • Lid lock facility allows for internal temperature maintenance even after centrifugation
  • Intermittent temperature control mode, CFC-free refrigerant and low carbon life rotor capacity
  • Brushless motor drive, maintenance free
  • High quality aluminum alloy bio-containment rotors, safe and autoclavable for unlimited service life
  • Special double cooling air design, reduces rotor heating
  • -20°C to 40°C temperature range
  • Powerful compressor and cooling system, fast cooling
  • Optional rotors below include a 4 x 8-tube PCR strip rotor
  • Pulse operation for quick spins
  • Interlock automatic door lock
  • Over-speed detection
  • Over-temperature detector
  • cTUVus approved for UL and CSA
  • Max. Speed    15000rpm(200-15000rpm), increment:10rpm
  • Max. RCF    21380×g, increment:10×g
  • Speed accuracy    ±20rpm
  • Temperature Range    -20°C to 40°C
  • Rotor Capacity  5mL×12, 1.5mL/ 2.0mL×24, 0.5mL×36, PCR8×4
  • Run Time    30sec-99mins/continuous
  • Driving Motor    Brushless DC motor
  • Safety Devices    Door interlock, Over-speed detection, Over-temperature detection, Automatic internal diagnosis
  • Power    Single-phase, AC220V-240V, 50Hz/60Hz, 10A, AC110V-120V, 50Hz/60Hz, 10A 400W
  • Acceleration/Braking time    25s↑ 25s↓
  • Dimension[WxDxH]    338×580×324mm
  • Weight    30kg
  • Certification    CE cTÜVus FCC MCA
  • Advanced features    Speed/RCF switch; Short-time run function; sound-alert function
