Hacker Instruments & Industries - OTF Series
by Hacker Instruments & Industries
Microtome
Legendary performance - Incomparable results! OTF is designed for optimum efficiency, versatility and consistent quality. The only cryostat with dual parallel compressors. A broad range of accessories and options allows the user to custom configure the OTF to meet their specific needs. Typical applications include Histochemistry, Neuroscience,"Whole Body" Studies, Autoradiography, Immuno-Histochemistry, Materials R & D, Immuno- Fluorescence as well as Routine Surgical Pathology.
-Ross
Thu Jan 28 2016
Vibratome UltraPro 5000 Cryostat
Is anyone familiar with the microtome in this unit. I'm looking for PM or adjustment or service data.
I've seen these in a couple of university labs. They appear to special Vibratome (vibrating) microtomes housed in a Bright OTF 5000 cryostat cabinet. Online searches indicate that there was a company called "The Vibratome Company," fifteen years ago, but its website yields error 404, now. Also, Leica now appears to be making microtomes (not cryostats) using the "Vibratome" name, so Leica might have acquired the technology.
Ross Hansohn
-Tomko Services, Inc.
Wed Aug 19 2015
OTF 5000 Manual
Does anyone have an electronic copy of the service manual for the Bright OTF 5000 cryostat. The Building we were in experienced a fire and the smoke and water damage has rendered our bound paper manuals useless. Thanks in advance!
  • New contoured top for added operator comfort; 2 package configurations with OTF’s most popular options
  • Interchangeable knife blocks for disposable and standard knives including a new lever release
  • Feather blade holder; automatic evaporator defrost supplied as standard; non-urgent features located on side panel plus a long list of options and accessories.
  • Maximum specimen size 50mm x 70mm
  • Total feed range 5.6mm
  • Head movement plus 44mm knife holder movement
  • Advanced/rewind speeds 116µm/s (slow) 164µm/s (fast)
  • Knife angle adjustment 25°
  • Specimen holder Standard vice clamp
  • Knives - Conventional knives and disposable blades
  • Evaporator defrost Automatic with analogue clock with battery back-up
  • Window surround Heated
  • Window demist system
  • Fan driven, automatic
  • Shelves 3 internal; 1 external
  • Surface finishes Easy clean, scratch and solvent resistant, flame retardant
  • Non urgent controls side mounted
  • Dimensions W 880mm max H 1250mm D 840mm
  • Weight 120kg manual 140kg
