Leica Biosystems - CM1850
Cryostat for standard applications in the clinical histopathology laboratory.The Leica CM1850 cryostat design incorporates emphasis on power savings, increased efficiency and operator safety. The result is a versatile cryostat with an optimized cooling system, rapid specimen freezing and smooth specimen orientation for the high-quality sectioning demanded in routine histology and clinical pathology.
FORUMSView All (32)
4Replies2 months ago | Error 15 I am getting error 15 on machine? Equipment: Leica Biosystems - CM1850 Reply |
0Replies5 months ago | System dpes not power up.... power gets to board. Hello all and I appreciate any help I can get here. My CM-1850 does not turn on. The compressor makes no noise, and the display does not show anything. However, some power must be getting to the board, because 2 red LEDs light up. I am assuming this is some sort of error code, but I have no clue how to decipher. Any help on next steps would be greatly appreciated. Reply |
0Replies5 months ago | Battery code EO021 Hello: Can i get info about error EO021 control board battery exhausted.I cannot find a battery Equipment: Leica CM1850 Reply |
VIDEOS
- Logically and ergonomically arranged user interface means a shorter learning curve and fewer operating errors.
- Condensate bottle supports a safer environment and increased user safety through easier collection, decontamination and discarding of the liquid condensate.
- Fast and smooth specimen orientation with zero-position centering.
- Specimen retraction avoids contact between cut specimen surface and blade on the return stroke for improved section quality.
