Leica Biosystems - CM1850
Cryostat for standard applications in the clinical histopathology laboratory.The Leica CM1850 cryostat design incorporates emphasis on power savings, increased efficiency and operator safety. The result is a versatile cryostat with an optimized cooling system, rapid specimen freezing and smooth specimen orientation for the high-quality sectioning demanded in routine histology and clinical pathology.
FORUMSView All (29)
3Repliesa year ago | NOT REACHING THE TEMPERATURE PROPERLY CABINET TEMPERATURE NOT GETTING -23, ROOM TEMPERATURE IS ALMOST 26deg C Equipment: lEICA CM1850 Reply |
0Repliesa year ago | PROPER TEMPERATURE NOT GETTING INSIDE THE UNIT PROPER TEMPERATURE NOT GETTING INSIDE THE UNIT Equipment: LEICA CM 1850 Reply |
0Replies3 years ago | PM Procedure Is there a guide or checklist for the PM Procedure?Reply |
VIDEOS
Crydom TechLab 1 - How to perform an operational on-off test on a solid state relay
- Logically and ergonomically arranged user interface means a shorter learning curve and fewer operating errors.
- Condensate bottle supports a safer environment and increased user safety through easier collection, decontamination and discarding of the liquid condensate.
- Fast and smooth specimen orientation with zero-position centering.
- Specimen retraction avoids contact between cut specimen surface and blade on the return stroke for improved section quality.
