Leica Biosystems - CM1950
Cryostat
The Leica CM1950 is a highly adaptable platform that can be tailor-made for each laboratory.
FORUMSView All (22)
0Replies2 years ago | Service software login Dear all Biomedical Eng. I need your help obtaining the User name & Password to login into service software of the cryostat Thank you tamimj@hmc.co.il Equipment: Leica Biosystems - CM1950 Reply |
1Reply3 years ago | Blinking Red Wrench We have a pretty new Leica CM1950 and the device has a blinking red wrench on the panel. The PM has just been done recently and the device has no apparent issues other than the blinking light. Is there a way to reset this and make it go away?Reply |
0Replies4 years ago | Leica CM1950 object cooling A client has four Leica CM1950 cryostats. The two older ones are leaking refrigerant in the object cooling system. One has a very slow leak, but the other one is leaking faster and faster. It appears to be in the flexible liquid line. I checked the service manual, but couldn't find a part number. Does anyone know the part number? Has anyone replaced these? Reply |
- UVC disinfection minimizes risk of contamination by infectious material
- AgProtect, an antimicrobial, nanosilver coating on all outside surfaces also minimizes contamination risk
- Optional section waste removal system provides a safer environment using a concealed primary filter system for solid waste and a bacterial (HEPA) filter for air.
- Optional vacuum assisted sectioning makes sectioning easier.
Maximum specimen size: 50 x 80 mm
Total specimen feed: 25 mm
Vertical specimen stroke: 59 mm
Specimen retraction: 20 µm or off
Specimen orientation: 8° (x-, y-axis), 360° rotation of specimen disc
Operating temperature range: 18°C to 35°C
Relative humidity: max. 60%, non-condensing
Storage humidity: < 60%
Dimensions and Weights
Width (without handwheel): 700 mm
Width (with handwheel): 835 mm
Depth (cabinet only): 850 mm
Height (total): 1215 mm
Working height (armrest): 1025 mm
