Leica Biosystems - CM3050 S
by Leica Biosystems
Cryostat
The Leica CM3050 S cryostat features superior user comfort with excellent safety standards for practically all types of cryosectioning applications. It is the instrument of choice for all research applications and for advanced clinical cryosectioning needs. Particularly when working with delicate specimens for example brain samples in neuroscience the precise specimen orientation and the specimen feed system guarantees reproducible, thin, serial sections of maximum quality.
FORUMSView All (12)
-Petia
6 months ago
Errating specimen head temperature
Hello,
I am experiencing an issue with the specimen head cooling. I had set my chamber temperature (CT) at negative 18C and object temperature (OT) at negative 22C when suddenly the OT started decreasing to negative 44C. Then the OT went back to the set temperature of negative 22C to start decreasing again in short time and then it repeated. Could you please advise what may the issue be? What can I do to fix this issue?
Thank you for your time!
Petia
Equipment: Leica Biosystems - Cryostat - CM3050S
-cryogenic
2 years ago
Leica cm3050S motor not working to advance or retract specimen head
leica cm3050S --motor stalled was completely locked up,I replaced motor but still not functioning, is there a motor drive board or fuse besides the 4 under the left panel that i can check
-cryogenic
2 years ago
service manual
fuse location
Equipment: Leica Biosystems - CM3050 S
  • Exceptionally precise stepper motor promotes the production of high quality sections of consistent thickness.
  • Fine orientation control supports sectioning of delicate tissues.
  • Optional motorized sectioning provides reproducible section quality and thickness and reduces repetitive motion.
  • Programmable reverse counter saves time by promoting fast trimming between levels (step sectioning).
