Biotec Fischer - EV2XX
by Biotec Fischer
Electrophoresis System
All models are method programmable with up to 9 different programmes each with 9 steps
Timer or volt-hour controlled operation: The microcomputer will automatically terminate the run and sound an alarm when the countdown to the selected value is complete
Each model can constantly monitor the behaviour of all parameters to prevent depletion of the buffer in the electrophoresis tank by terminating the run when abnormal changes occur
Data logging: Stores up to 3600 output values (voltage, current and power, time or volthours) including programme number and step
All power supplies can be controlled by a computer using special commands
Up to nine different programmes, each with nine steps, of frequently used parameters can be stored in the non-volatile memory for future recall. All units read voltage in 1 V increments, current in 1 mA increments and power in 1 W increments
