Biotec Fischer - Phero-Sub 0710- E
by Biotec Fischer
Electrophoresis System
PHERO-sub 0710-E is the smallest unit in the range, designed for low to medium numbers of samples. The small gel size maximises run economy but does not compromise versatility as two tray options are available – 7 x 7cm and 7 x 10cm, and combs ranging from preparative up to 16 samples. Simply by altering the gel tray or comb, this compact unit is capable of resolving up to 64 different samples, prepping 1ml of sample or separating sample bands over a distance of 9cm.
111100-001
1 x Gel Tray 70 x 70 mm, UV transparent
1 x Casting Dams ( 2 pcs.)
2 x Comb, 8 slots, 1.0 mm
Loading guides, Platform, Cable set
111100-002
1 x Gel Tray 70 x 100 mm, UV transparent
111100-003
