Biotec Fischer - Phero-Sub 1008-E
by Biotec Fischer
Electrophoresis System
he PHERO-sub 1008-E is a completely self contained system designed for quick checks of samples. Gel casting, running and analysis are all performed in the same ultra compact unit. Buffer and gel volumes have been kept to a minimum and the parallel electrode arrangement allows ultra efficient current transfer, enabling resolution to be completed within 30 minutes. The UV transparent base allows direct viewing on a UV Transilluminator with no need for time consuming transfer and potential gel damage.
111200-001 PHERO-sub 1008-E
1 x Gel Tray 100 x 80 mm, UV transparent
1 x Casting Dams ( 2 pcs.)
2 x Comb, 8 slots, 1.5 mm
Cable set
