Biotec Fischer - Phero-Sub 1010-E
by Biotec Fischer
Electrophoresis System
With gel tray options of 10 x 7cm and 10 x 10cm, the multiSUB Midi has been designed for routine horizontal gel electrophoresis. Extending only the width of this unit allows more samples to be resolved per gel than the PHERO-sub 1010-E without a significant increase in buffer or gel volumes. A maximum of 100 samples per gel can be resolved making this unit ideal for those routinely checking medium numbers of samples over short to medium gel run lengths.
111300-001 PHERO-sub 1010-E
1 x Gel Tray 100 x 70 mm, UV transparent
1 x Casting Dams ( 2 pcs.)
2 x Comb, 16 slots, 1.0 mm
Loading guides, Platform, Cable set
111300-002 PHERO-sub 1010-E
1 x Gel Tray 100 x 100 mm, UV transparent
111300-003 PHERO-sub 1010-E
