SIUI - Apogee 3800
by SIUI
Apogee 3800 has got matrix array imaging technology which is developed based on relevant imaging technology.
The system receives the ultrasound signal in matrix array instead of traditional ultrasound beam receiving, carries out special relevant processing and delivers optimal images. In application of this technology, the system resolution is sharply improved, and the images are clear and direct enough so as to enhance the diagnosis efficiency.
0RepliesFri Apr 22 2022 | FAILED START UP TEST Startup tests and displays an error "Failed DL Memories Test" and the ultra sound module doesn't work. What do I have to do?Reply |
0RepliesFri Apr 22 2022 | SIUI Software corrupted When booting the SIUI software, it performs startup tests and displays an error "Failed DL Memories Test" and the ultra sound module doesn't work. What do I have to do? Please shared a service manual from SIUI Apogee 3800 Reply |
| Cart Based | 1 |
| Height | 59.05 in |
| Length | 40.55 in |
| Weight | 240.3 lbs |
| Clinical Applications | Colorectal |
| Imaging Capabilities | 2D/3D |
| Color-flow Mapping | 1 |
| Doppler Modes | Colour Doppler Triplex Mode |
| Image Display | 15 in |
| Imaging Mode | B, 2B, 4B, M, B/M |
| Width | 26.38 in |
Frequency Range: 1.7Mhz - 12.0Mhz
