Biotec Fischer - Phero- Sub 2020-E
Electrophoresis System
The PHERO-sub 2020-E primarily designed for resolution of high numbers of samples such as from Cloning or PCR. The PHERO-sub 2020-E allows ultra high-resolution separations over extended runs. Tray sizes correspond to standard blotter sizes. It also allows easy sample transfer onto a membrane for further analysis. Three tray sizes are available – 20 x 20cm, 20 x 25cm and a half-length 20 x 10cm.
111500-001 PHERO-sub 2020-E
1 x Gel Tray 200 x 100 mm, UV transpar.
1 x Casting Dams ( 2 pcs.)
2 x Comb, 20 slots, 1.0 mm
Loading guides, Platform, Cable set
111500-002 PHERO-sub 1010-E
1 x Gel Tray 200 x 200 mm, UV transpar.
111500-003 PHERO-sub 1010-E
111500-004 PHERO-sub 2020-E
1 x Gel Tray 200 x 250 mm, UV transpar.
