Biotec Fischer - Phero-Sub 2632- E
by Biotec Fischer
Electrophoresis System
Designed for rapid screening of very large numbers of Clonal or PCR samples, the PHERO-sub 2632-E horizontal gel unit has a 672 maximum sample capacity per gel. This allows loading and analysis of exactly seven 96 well format micro titre plates. The large gel run length of 32cm also allows resolution of samples over a long distance for separation of complex sample bands such as in restriction fragment analysis.
111600-001 PHERO-sub 2632-E
1 x Gel Tray 260 x 160 mm, UV transparent
1 x Casting Dams ( 2 pcs.)
6 x Comb, 28 slots, 1.0 mm
Loading guides, Viewing Platform, Cable set
111600-002 PHERO-sub 2632-E
1 x Gel Tray 260 x 240 mm, UV transparent
111600-003 PHERO-sub 2632-E
1 x Gel Tray 260 x 320 mm, UV transparent
111600-004 PHERO-sub 2632-E
