Techne - SBH130DC/SBH200DC
by Techne
Block Heater
A block heater provides a source of precise heating for many sensitive analytical procedures. Through choice of block, a wide variety of tubes and vessels can be accommodated in a standard unit.
The Stuart range of block heaters are available in two or three block versions and dual control models, where two blocks can be held at independent temperatures.
Two blocks with independent temperature control
130°C or 200°C maximum temperature
Digital setting and display
Uniform and stable temperatures
Innovative design accommodating 2 blocks with independent temperature control allowing them to be set at different temperatures.
| Temperature range | Ambient +8°C to 130°C | 50°C to 200°C |
| Temp. stability | ±0.1°C | ±0.1°C |
| Uniformity within block at 60°C | ±0.1°C | ±0.1°C |
| Uniformity within block at max temp. | ±1°C | ±1°C |
