BINDER - Series KBF
by BINDER
Humidity Test Chambers
The BINDER KBF is the specialist for unconditionally reliable stability testing and precise maintenance of constant climate conditions. From programming to documentation, this humidity test chamber meets all critical requirements.
Safe thanks to climatic homogeneity that far exceeds the accuracy required by ICH guidelines, even with a fully loaded unit.
Reliable thanks to failsafe operation without compromise. The interior and Longlife evaporator plate are made entirely from stainless steel.
Smart, as a wide range of accessories makes it highly compatible for adaptation to specific customer requirements
emperature range: 0 °C to +70 °C
Humidity range: 10 % to 80 % RH
APT.line™ preheating chamber technology
Humidity regulation with capacitive humidity sensor and vapor humidification
Intuitive touchscreen controller with time-segment and real-time programming
