AGFA - Mamoray Classic E.O.S.
by AGFA
Film Processor
The MAMORAY Classic E.O.S. processor is an optimized processor for mammography. Reliable and consistent processing provides quality images without compromise in speed. The MAMORAY Classic E.O.S. processor is optimized for mammography film processing. Based on the proven technology implemented in the other Agfa equipment - such as the Classic E.O.S - this mammography darkroom film processor combines photographic consistency with reduced chemical costs. Suitable for following market segments Processing of mammography images
FORUMSView All (4)
-Hsaeed
Mon Apr 06 2020
Service manual
I want this book for this machine Agfa classic eos  please
-skacel
Sat Feb 22 2014
guide de maintenance
error 550
-CRISTALINO
Tue Oct 16 2012
agfa classic e.o.s. and compact e.o.s. parts
can i use the rollers,and other parts  of the  agfa compact e.o.s. processor,  for a  agfa classic e.o.s. processor?
thank you very much for your attention
carlos diaz
servicios y equipos medicos
For reliable mammography optimized processing with reduced chemical costs, look no further than the MAMORAY Classic E.O.S. processor. Agfas Ecologically Optimized System With Agfa's unique "Ecologically Optimized System" approach, the MAMORAY Classic E.O.S. processor allows you to comply with ecological standards while reducing fixer consumption, silver content in the wash water and water consumption. The silver content in the washing water is reduced to 1 ppm at regular water consumption rates, and to 50 mg/m² at reduced water consumption rates. Excellent image quality The racks in the MAMORAY Classic E.O.S. processor have been specially designed for dedicated mammographic processing or for mixed processing of general radiographic and mammographic images. The result is image quality that meets the most stringent regulations imposed by different countries. The MAMORAY Classic E.O.S. processor offers you a choice of processing cycles: RP (Rapid Processing) and EXT (Extended Cycle), providing you with optimum image quality of your films. IP (Intermediate Processing) will be added to new E.O.S. universal software. Photographic consistency The developer temperature can be selected and monitored through a control panel. The developer temperature will be controlled within a tolerance rate of ±0.3 °C. Room to insert a thermometer to calibrate and monitor the photochemical process has been foreseen. The automatic jog cycle will replenish the chemicals at regular intervals to ensure optimum processing conditions. All these features contribute to consistent image quality, facilitating daily quality control. User-friendliness The MAMORAY Classic E.O.S. processor's functions are microprocessor-controlled. Its user-friendly control panel has an interactive 2 x 16 digit LCD display (12 languages). The MAMORAY Classic E.O.S. processor offers you the very best in processing technology. Its infrared drying modules provide superior drying performance and generate low heat so as not to disturb the working environment. Easy installation A single phase, 15/16 A wall outlet and standard plumbing connections are all you need to install the MAMORAY Classic E.O.S. processor properly.
