Huntleigh - Sonicaid FM800
by Huntleigh
Fetal/Maternal Monitor
The Sonicaid FM800 Encore- Fetal/Maternal Monitor is a high performance fetal and maternal monitor, using todays most advanced technology to produce the most accurate acquisition of data for clinician decision support. Whether you need standard fetal monitoring or equipment for specialist, high-risk care, the Sonicaid FM800 Encore series gives you accuracy and clarity in every situation. In the fast-paced environment of the labor ward, you need equipment that’s easy to use and data that is quick to read. The Sonicaid FM800 Encore gives you comprehensive fetal /maternal monitoring and analysis in one technologically advanced yet simple to use monitor.
Antepartum CTG analysis- Provides and objective, numerical and consistent assessment of the CTG. Clinicians can rely on the worlds largest database of collective experience to support their own visual assessment.
Intrapartum trend- Measures changes over time in the FHR. For use during the 1st stage of labor, clinicians are quickly alerted to changes in short term variability, baseline rate and deceleration size.
Height | 18.6 cm |
Length | 31 cm |
Weight | 9.5 kg |
Width | 35.3 cm |
Technique : Directional Pulsed Doppler
Frequency: 1 MHz
Measurement Range: 30-240 BPM
Fetal Scalp Electrode: Supports all variants of FEOG
