Mindray - ePM 10M/12M
by Mindray
Passport Monitoring
The evolution of Passport® Monitoring has arrived – Mindray’s ePM 10M and 12M monitors are the inspired result of cutting-edge innovation and exceptional efficiency, continuing the Passport legacy in monitoring. Experience the immediate and measurable benefits of the smartphone-like user interface that delivers 90% of all common monitoring functions with just 2 gestures. A single swipe enables clinicians to see patient data in large numerics mode then swipe again, and a mini-trend window provides an immediate view of critical patient data, smoothing workflow at point-of-care.
The ePM 10M and 12M offer a plug-and-play module structure for more advanced monitoring functions such as CO2, aiding clinicians to identify signs of patient deterioration due to respiratory distress. The ePM 12M paired with the ePM multi-gas module, automatically identifies and measures the inspired and expired values of O2, CO2, N2O and 5 anesthetic agents providing a compact, yet powerful OR monitoring solution. Integrated in each ePM monitor; 3 and 5- lead ECG, SpO2, NIBP, respiration, and temperature, offering a robust parameter platform to meet the needs of the ambulatory surgical care environment.
3RepliesTue Sep 03 2024 | Printing Problem Dear All, Mindray ePM 12M After turning on the monitor the top bar displays alternating messages, alternating between printer unavailable and the following messages: The display set up for O2 is disabled The display set up for Gas is disabled The display set up for Arrhythmia is disabled The display set up for Resp is disabled Recorder out of paper The recorder is not out of paper and I can print using the button above the paper loading door. To my knowledge I have not disabled any display feature. If anybody can help me on the right direction I would be grateful. Simon Prior Reply |
0RepliesFri Apr 26 2024 | How to turn off Resp disturbed alarm Hello! Our passport 12m resp alarm is so sensitive, literally every time the surgeon uses the cautery, it alarms. The only current solution is silencing alarms every 3 minutes which is not viable. Can someone please tell me how to adjust or disable this technical alarm. Reply |
