Patient Monitoring
The Mindray Passport 17m is a patient monitor that can be used on adult, pediatric, and neonatal patients. This Passport monitor is intended for monitoring and displaying ECG (3, 5, and 12-lead), Arrhythmia Detection, ST-segment Analysis, QT Analysis, Heart Rate, Respiration, Temperature, SpO2, Pulse Rate, NIBP, IBP, PAWP, Cardiac Output, Continuous Cardiac Output, SvO2, CO2, O2, Anesthetic Gas, ICG, BIS, RM, and interpretation of resting 12-lead ECG.
- Supports 12 different modules that include SpO2, MPM, IBP, C.O., CCO/ ScO2, CO2, AG, BIS, RM, ScvO2, T1, and BeneLink.
- Supports the Mindray T1 as a multi-measurement module. When disconnected the T1 can be used as a stand-alone monitor.
- 4 different operating modes include Monitoring Mode, Night Mode, Privacy mode, and Standby Mode.
- 5 default configurations include General, OR, ICU, NICU, and CCU.
| Height | 15.7 in |
| Length | 0 in |
| Weight | 26.5 |
| Width | 14.5 in |
Display:
- Type: Color TFT LCD
- Screen Size (Diagonal): 17”
- Resolution: 1280x1024
Recorder:
- Method: Thermal dot array
- Horizontal Resolution: 16 dots/mm (25 mm/s paper speed)
- Vertical Resolution: 8 dots/mm
- Paper Width: 50 mm
- Paper Length: 20 m
- Paper Speed: 25 mm/s, 50 mm/s
- Number of Waveform Channels: Maximum 3
MPM Module:
- ECG
- Leads: 3, 5, and 12-Lead
- Sampling Rate: 500 samples/s (A/D); 500 samples/s (ECG algorithm)
- Accuracy: 2.44μV/LSB
- Heart Rate: Yes
- ST Segment Analysis: Yes
- Respiration
- Measurement Range: Adult: 0 to 120 rpm ; Pediatric, neonate: 0 to 150 rpm
- Resolution: 1 rpm
- Accuracy: 7 to 150 rpm (±2 rpm or ±2%, whichever is greater)
- SpO2
- SpO2 High: (low limit + 2) to 100
- SpO2 Low: Masimo: Desat to (high limit – 2); Nellcor: Desat or 20 (whichever is greater) to (high limit – 2)
- Desat: 0 to (high limit – 2)
- Temperature
- Measurement Range: 0 to 50 °C (32 to 122°F)
- Resolution: 0.1 °C
- Accuracy: ±0.1 °C or ±0.2 °F (without probe)
- NIBP
- Mode of Operation: Manual, Auto and STAT
- Max Measurement Time: Adult/Pediatric: 180 s; Neonate: 90 s
- Heart Rate Range: 40 to 240 bpm
- Accuracy: Max mean error: ±5 mmHg; Max standard deviation: 8 mmHg
- Resolution: 1mmHg
- IBP
- Measurement Range: -50 to 300 mmHg
- Resolution: 1 mmHg
- Accuracy: ±2% or ±1 mmHg, (whichever is greater (without sensor))
- PPV Measurement Range: 0% ~ 50%
