Allied Healthcare Products - Shuco S130A
Aspirator
The Schuco S130A suction pump is a quiet, dependable, vibration-free suction machine used to remove mucus from the airways. The Schuco S130A features a corrosion resistant, thermal protected motor, and permanent lubrication for maintenance-free operation.
SERVICE COMPANIESView All Aspirator Companies
UL approved - meets IEC 60601-1
• Flow range higher than ever - over 40 lpm
• Every aspirator, suction pump, comes equipped with a hospital-grade plug
• Collection canisters with improved scratch and flake resistance
• High vacuum range for various suction needs - up to 560 mm Hg (22" Hg)
• Vibration-free gauge for easy reading and vacuum control
• Durable metal canister brackets accommodate a variety of collection containers
• Strong metal base
• Canister Size - 800ml
• Power - 115V 60Hz
