Alsa - Polivac B4/SLT 30 2
Surgical Suction pump
It is the basic model of the series and it is equipped with an oil bath pump. It is suitable for the operating theatre and other medical suction interventions.
SERVICE COMPANIESView All Aspirator Companies
Class IEC/CEI 60601-1: I BF.
- EC Certificate (93/42+2007/47): CE0051 - nr. 187/MDD.
- Usage for unlimited time / Noise: less than 50 db.
- Power supply / Absorption: 230V - one phase, 50Hz / 400VA.
- Piston suction-group, maintenance free (max vacuum 700 mmHg “0,9 atm, 0,90 bar”, flow rate 70 l/min, engine: from 1/2 of HP).
- Painted metal case and antistatic wheels, two with castors.
- Two bottles of 4 l. made of unbreakable and autoclavable polycarbonate, with internal over-flow devices, and a quick system for the aspira-tion changing between bottles; silicone autocla-vable tubing (Ø mm 7x12).
- Vacuum regulator and vacuum check device (0-76 cm/Hg).- Main switch and pedal switch (pneumatic, very safe, water-proof, anti-explosion).
- Dimensions (width/depth/height), weight: cm 40x35x75 Kg 24.
– Note 1) It can be equipped with a disposable antibacterial filter, which works also as supplementary over-flow device;
– Note 2) Available pieces: external over-flow device, seat for the usage of disposable bottles of diam. from 9 to 16 cm (also for wall), cannulae-handle, stainless steel box for the accessories;
