Smoke Evacuation System
The complete solution for evacuating surgical smoke from your operating theatre. It’s one small box that makes a
big difference in your O.R. air
quality. It provides suction for
either SafeAir Smoke Evacuation
Pencil (standard or telescopic) and
is easily portable for use in the
O.R. or other procedure rooms.
Safety and Satisfaction:
- Helps reduce exposure to smoke related biohazards
Efficiency:
- Eliminates need for nurses with smoke tube, freeing up space at the table and hands to assist.
Integrates with existing monopolar electrosurgical generators and smoke evacuation systems (22mm inlet) like that in the Neptune 3 Waste Management System.
Performance:
- Helps maintain a clear operative site and its ergonomic design aids transition from standard electrosurgical pencils.
Ergonomics:
- Designed to preserve surgeons natural technique via a lightweight and ergonomic electrosurgical pencil.
- ULPA filtration in accordance with AORN guidelines.
- Auto-activation via integrated sensor that detects pencil current.
- Lighted indicator visibly tracks filter life ; shows when change is needed.
- Proprietary vacuum design enables near instant "on tip" suction at the power level set.
- Multiple activation codes; Automatic, continuous and footswitch.
- Adjustable time delay to enable maximum smoke evacuation.
| Height | 5.5 in |
| Length | 0 in |
| Weight | 28.66 lbs |
| Width | 14.96 in |
